DRAFT help
Basic Analysis > Oneway Analysis > Overview of Oneway Platform
Publication date: 09/20/2024
The Oneway platform enables you to quickly visualize the distribution of a continuous Y variable across two or more levels of a categorical X variable. You can evaluate differences in means or variances across groups. Methods include analysis of variance (ANOVA), analysis of means (ANOM), t tests, equivalence tests, nonparametric tests, exact tests, F tests, and multiple comparisons of means tests. Many tests add visualization tools to the Oneway plot in the report. In addition, there are options to use probability density function (PDF) and cumulative distribution function (CDF) plots to visualize the distribution of your response across the levels of the X variable.
Tests are grouped together in the Oneway red triangle menu according to the type of test. JMP enables you to explore many types of statistical tests. The best choice of test depends on the study design, data collection, data distributions, and the hypothesis of interest. For more information about these test reports, see Oneway Analysis Reports.
