DRAFT help
Publication date: 09/20/2024
Set Material Properties
To set the material properties of a surface, use the Material function.
Material( face, argument, value,...value )
face can be Front, Back, or Front_and_back. (Note that the material properties can be set separately for the front and back faces of a polygon.)
Table 13.5 shows the arguments and default values for Material arguments.
Table 13.5 Material Arguments and Default Values
Argument
Default Value
Meaning
AMBIENT
(0.2, 0.2, 0.2, 1.0)
Ambient color of material
DIFFUSE
(0.8, 0.8, 0.8, 1.0)
Diffuse color of material
AMBIENT_AND_DIFFUSE
Both AMBIENT and DIFFUSE
SPECULAR
(0.0, 0.0, 0.0, 1.0)
Specular color of material
SHININESS
0
Specular exponent that can range from 0 to 128.
EMISSION
(0, 0, 0, 1)
Emissive color of material
