DRAFT help
Publication date: 09/20/2024
Specify Lighting Models
Lighting models are specified with the Light Model function.
Light Model( argument, value,...,value )
Light models specify three attributes of lights.
The global ambient light intensity
Whether the viewpoint is local or is an infinite distance away
Whether lighting calculations should be performed differently for the front and back faces of objects.
Table 13.4 shows the three valid arguments for the Light Model function.
Table 13.4 Light Model Arguments and Default Values
Argument
Default Value
Meaning
LIGHT_MODEL_AMBIENT
(0.2, 0.2, 0.2, 1)
Ambient RGBA intensity of the entire scene
LIGHT_MODEL_LOCAL_VIEWER
0 (false)
how specular reflection angles are computed
LIGHT_MODEL_TWO_SIDE
0 (false)
nonzero values imply two-sided lighting
