DRAFT help
Reliability and Survival Methods > Fit Life by X > The Fit Life by X Report
Publication date: 09/20/2024
The initial Fit Life by X report contains the following sections:
Summary of Data
Scatterplot
Nonparametric Overlay
Comparisons
Results
Custom Relationship
The Comparisons report contains tabs for Distribution, Quantile, Hazard, Density, and Acceleration Factor profilers. You can also view and compare criteria values under Comparison Criterion.
The Results report contains tabs for parametric estimates, covariance matrices, nested model tests, and diagnostics. These results can be examined and compared for each of the selected distributions. You can also perform custom estimation and obtain Bayesian estimates for the distribution parameters.
Summary of Data
The Summary of Data section of the Fit Life by X report contains the total number of observations, the number of uncensored values, and the number of censored values (right, left, and interval).
