DRAFT help
Basic Analysis > Logistic Analysis > The Logistic Report
Publication date: 09/20/2024
The Logistic Report
The Logistic report initially contains a logistic plot and the Iterations, Whole Model Test, Fit Details, and Parameter Estimates reports. You can change the appearance of the logistic plot and request other plots using the red triangle menu options. See Logistic Platform Options.
This section contains information about the following sections of the Logistic report:
Logistic Plot
Iterations Report
Whole Model Test Report
Fit Details Report
Parameter Estimates Report
Figure 8.4 Example of a Logistic Report
Replace Variables Interactively
You can also replace a variable by selecting a variable in the Columns panel of the associated data table and dragging it onto an axis.
