DRAFT help
Quality and Process Methods > Process Capability > The Process Capability Report
Publication date: 09/20/2024
By default, the Process Capability report contains the following plots:
Goal Plot (provided only if at least one variable is fit with a normal distribution and shows only points for variables fit with normal distributions)
Capability Box Plots (provided only if at least one variable is fit with a normal distribution and shows only box plots for variables fit with normal distributions)
Capability Index Plot
Using the Process Capability red triangle menu, you can add individual detail reports, normalized box plots, and summary reports. The red triangle menu also has options for identifying out-of-spec values in your data table, creating a summary data table, changing the display order of analyzed columns, and saving out spec limits. These options are described in Process Capability Platform Options.
You can change the default report at File > Preferences > Platforms > Process Capability. You can also make changes to the appearance of reports produced by options by selecting the relevant Process Capability topic at File > Preferences > Platforms.
