Scatterplot 3Dオブジェクトに対する次のメッセージは、JSLでのみ使用できます。
scatterplot_3D_object << Frame3D( Add Ellipsoid( ... ) );
scatterplot_3D_object << Frame3D( Add Markers( ... ) );
scatterplot_3D_object << Frame3D( Add Vector( ... ) );
scatterplot_3D_object << Frame3D( Get Axes );
scatterplot_3D_object << Frame3D( Get Box );
scatterplot_3D_object << Frame3D( Get Grab Handles );
scatterplot_3D_object << Frame3D( Get Graph Size );
scatterplot_3D_object << Frame3D( Get Grids );
scatterplot_3D_object << Frame3D( Get Hide Lights Border );
scatterplot_3D_object << Frame3D( get light active( number ) );
scatterplot_3D_object << Frame3D( get light color( number ) );
scatterplot_3D_object << Frame3D( get light position( number ) );
scatterplot_3D_object << Frame3D( Get Line Scale );
scatterplot_3D_object << Frame3D( Get Marker Quality );
scatterplot_3D_object << Frame3D( Get Marker Scale );
scatterplot_3D_object << Frame3D( Get Marker Transparency );
scatterplot_3D_object << Frame3D( Get Rotation );
scatterplot_3D_object << Frame3D( Get Text Scale );
scatterplot_3D_object << Frame3D( Get View Ortho );
scatterplot_3D_object << Frame3D( Get View Perspective );
scatterplot_3D_object << Frame3D( Get View Zoom );
scatterplot_3D_object << Frame3D( Get Wall Color );
scatterplot_3D_object << Frame3D( Get Walls );
scatterplot_3D_object << Frame3D( Get X Axis Color );
scatterplot_3D_object << Frame3D( Get X Axis Label );
scatterplot_3D_object << Frame3D( Get Y Axis Color );
scatterplot_3D_object << Frame3D( Get Y Axis Label );
scatterplot_3D_object << Frame3D( Get Z Axis Color );
scatterplot_3D_object << Frame3D( Get Z Axis Label );
scatterplot_3D_object << Frame3D( Set Axes( 0|1 ) );
scatterplot_3D_object << Frame3D( Set Box( 0|1 ) );
scatterplot_3D_object << Frame3D( Set Graph Size( x, y ) );
scatterplot_3D_object << Frame3D( Set Grids( 0|1 ) );
scatterplot_3D_object << Frame3D( Set Hide Lights Border( 0|1 ) );
scatterplot_3D_object << Frame3D( set light active( ... ) );
scatterplot_3D_object << Frame3D( set light color( ... ) );
scatterplot_3D_object << Frame3D( set light position( ... ) );
scatterplot_3D_object << Frame3D( Set Line Scale( number ) );
scatterplot_3D_object << Frame3D( Set Marker Quality( number ) );
scatterplot_3D_object << Frame3D( Set Marker Scale( number ) );
scatterplot_3D_object << Frame3D( Set Marker Transparency( number ) );
scatterplot_3D_object << Frame3D( Set Oscillation( ... ) );
scatterplot_3D_object << Frame3D( Set Rotation( ... ) );
scatterplot_3D_object << Frame3D( Set Spin( ... ) );
scatterplot_3D_object << Frame3D( Set Text Scale( number ) );
scatterplot_3D_object << Frame3D( Set View Ortho( 0|1 ) );
scatterplot_3D_object << Frame3D( Set View Perspective( number ) );
scatterplot_3D_object << Frame3D( Set View Zoom( number ) );
scatterplot_3D_object << Frame3D( Set Wall Color( number ) );
scatterplot_3D_object << Frame3D( Set Walls( 0|1 ) );
scatterplot_3D_object << Frame3D( Set X Axis Color( color ) );
scatterplot_3D_object << Frame3D( Set X Axis Label( string ) );
scatterplot_3D_object << Frame3D( Set Y Axis Color( color ) );
scatterplot_3D_object << Frame3D( Set Y Axis Label( string ) );
scatterplot_3D_object << Frame3D( Set Z Axis Color( color ) );
scatterplot_3D_object << Frame3D( Set Z Axis Label( string ) );
scatterplot_3D_object << Frame3D( XAxis( ... ) );
scatterplot_3D_object << Frame3D( YAxis( ... ) );
scatterplot_3D_object << Frame3D( Z Axis( ... ) );
scatterplot_3D_object << Nonpar Density Contour Settings( ... );
