Scripting Guide > Extending JMP > Work with Python > Equivalent Data Types for Python Get()
发布日期: 04/13/2021
Table 14.6 shows which JMP data types can be exchanged with Python using the Python Get() function. Getting lists from Python recursively examines each element of the list and gets each base Python data type. Nested lists are supported.
Table 14.6 Equivalent Python and JMP Data Types for Python Get()
Python Data Type
JMP Data Type
Array
Numeric Matrix
Date and time
Numeric
Pandas.DataFrame
Data Table
Dictionary
Associative Array
Graph
Picture Object
Integer
Integer
List
List of converted Python data types
Matrix
Numeric Matrix
Set
List
Unicode String
String
Python Get() Example
Python Init();
x1 = [1, 2, 3];
Python Send( x1 );
x2 = Python Get( x1 );
Show( x1, x2 );
dt1 = Open( "$SAMPLE_DATA/Big Class.jmp" );
Python Send( dt1 );
dt2 = Python Get( dt1 );
dt2 << New Data View;
Close( dt1 );
Python Term();
