发布日期: 04/13/2021
Hover Labels
When you hover over a visual element in a graph, usually you see a basic description of the data point on a hover label.
You can customize what appears on the hover label using the following methods:
Add Rich Text to Hover Labels Using Textlets
Add Graphs or Images to Hover Labels Using Graphlets
Update Names and Values in Hover Labels Using Gridlets
Create Drill-Down Graphs
Work with the Hover Label Execution Context
