Scripting Guide > Types of Data > Regular Expressions > Special Characters in Regular Expressions
发布日期: 04/13/2021
Special characters are commonly used in regular expressions. The period is a special character that matches one instance of the specified character. It must be escaped with a backslash to be interpreted as a period. In the following expression, the period is replaced with an exclamation point.
Regex( "Bicycling makes traveling to work fun.", "\.", "!", GLOBALREPLACE );
"Bicycling makes traveling to work fun!"
Table 6.8 describes the special characters and provides examples.
Table 6.8 Special Characters in Regular Expressions
Precedes a literal character.
<\/a> interprets the forward slash literally in the end HTML anchor tag.
Precedes an escape sequence.
\n matches a newline character.
Matches the beginning of a string, not including the newline character.
^apple matches “apple” at the beginning of a string.
Matches the end of a string, not including the newline character.
apple$ matches “apple” at the end of a string.
Matches any single character including a newline character.
.apple matches any single character and then “apple”.
Represents a logical OR to separate alternative values.
(apple|orange|banana) matches “apple”, “orange”, or “banana”.
Matches zero or one instance.
apple (pie)? matches one or more instances of “pie”.
Matches zero or more instances.
Matches one or more instances.
Encloses a sub-expression.
^(\w+) matches the beginning of a line and then one or more word characters.
Encloses an expression that matches set of characters.
[\s] matches a whitespace character or a digit.
[a-z0-9] matches “a” through “z” and numbers “0” through “9”.
Encloses an expression that represents repetition.
apple{3} repeats three times.
apple{3,} repeats at least three times as many times as possible.
apple{3, 10} repeats three times but no more than 10 times.
Append a question mark to indicate repeating as few times as possible. For example, apple{3,}? repeats at least three times as few times as possible.
