Scripting Guide > Three-Dimensional Scenes > Three-Dimensional Arguments
发布日期: 04/13/2021
Arguments enable you to specify special modes and settings. To enable an argument, use the Enable(argument) command. To disable an argument, use the Disable(argument) command. Available arguments are shown in Table 13.7.
Table 13.7 Arguments
ALPHA_TEST
AUTO_NORMAL
BLEND
CLIP_PLANE0
CLIP_PLANE1
CLIP_PLANE2
CLIP_PLANE3
CLIP_PLANE4
CLIP_PLANE5
COLOR_LOGIC_OP
COLOR_MATERIAL
CULL_FACE
DEPTH_TEST
DITHER
FOG
LIGHT0
LIGHT1
LIGHT2
LIGHT3
LIGHT4
LIGHT5
LIGHT6
LIGHT7
LIGHTING
LINE_SMOOTH
LINE_STIPPLE
MAP1_COLOR_4
MAP1_INDEX
MAP1_NORMAL
MAP1_TEXTURE_COORD_1
MAP1_TEXTURE_COORD_2
MAP1_TEXTURE_COORD_3
MAP1_TEXTURE_COORD_4
MAP1_VERTEX_3
MAP1_VERTEX_4
MAP2_COLOR_4
MAP2_INDEX
MAP2_NORMAL
MAP2_TEXTURE_COORD_1
MAP2_TEXTURE_COORD_2
MAP2_TEXTURE_COORD_3
MAP2_TEXTURE_COORD_4
MAP2_VERTEX_3
MAP2_VERTEX_4
NORMALIZE
POINT_SMOOTH
POLYGON_OFFSET_FILL
POLYGON_OFFSET_LINE
POLYGON_OFFSET_POINT
POLYGON_SMOOTH
POLYGON_STIPPLE
SCISSOR_TEST
STENCIL_TEST
