发布日期: 09/18/2023
Get Column Names
The Column Name(n) message returns the name of the n th column.
Column Name( 2 );
age
The returned value is a name value, not a quoted string. What this means is you can use it anywhere you would normally use the actual name in a script. For example, you could subscript it:
Column Name( 2 )[1];
12
If you want the name as a text string, quote it with Char:
Char( Column Name( 2 ) );
"age"
To retrieve a list of the column names in a data table, submit Get Column Names.
dt << Get Column Names( argument );
where the optional argument controls the output of the Get Column Names message, as follows:
Specify Numeric, Character, or RowState to include only those column data types.
Specify Continuous, Ordinal, or Nominal to include only those modeling types.
To get all columns names, specify no data type or modeling type.
Specify String to return a list of strings rather than column names.For example, if you want to get numeric and continuous columns in the Big Class.jmp sample data table, proceed as follows:
names = dt << Get Column Names(Numeric, "Continuous")
{height, weight}
