Scripting Guide > Data Tables > Work with Columns
发布日期: 09/18/2023
Work with Columns
This section covers JSL actions that you can perform on columns in a data table, such as creating, grouping, and setting and getting attributes and properties.
Send Messages to Data Column Objects
Create Columns
Create a New Column by Text Matching
Add Several Columns at Once
Group Columns
Use Set Selected to Select Columns
Rearrange and Move Columns
Recode Columns
Add a Column Switcher
Compress Selected Columns
Create Custom Functions, Transforms, and Formats
Custom Transform Example
Delete Columns
Get Column Names
Set or Get Column Attributes
Set or Get Column Properties
Note: JMP can display math symbols and Greek letters (controlled in Preferences in the Font category). This means that if you save a column (such as T square limits), the column name could either be “T Square Limits” (no special characters) or “T2 Limits” (with special characters). Any reference using the column name must match the name exactly, or it fails.
