《拟合线性模型》引用了以下资料来源。
Aitken, M. (1987).“Modelling Variance Heterogeneity in Normal Regression Using GLIM.”Journal of the Royal Statistical Society, Series C 36:332–339.
Akaike, H. (1974).“A New Look at the Statistical Model Identification.”IEEE Transactions on Automatic Control AC-19:716–723.
Albers, C., and Lakens, D.(2018).“When Power Analyses Based on Pilot Data are Biased: Inaccurate Effect Size Estimators and Follow-up Bias.”Journal of Experimental Social Psychology 74:187–195.
Anderson, T. W. (1958).An Introduction to Multivariate Statistical Analysis.New York: John Wiley & Sons.
Belsley, D. A., Kuh, E., and Welsch, R. E. (1980).Regression Diagnostics: Identifying Influential Data and Sources of Collinearity.New York: John Wiley & Sons.
Benjamini, Y., and Hochberg, Y. (1995).“Controlling the False Discovery Rate: A Practical and Powerful Approach to Multiple Testing.”Journal of the Royal Statistical Society, Series B 57:289–300.
Box, G. E. P. (1954).“Some Theorems on Quadratic Forms Applied in the Study of Analysis of Variance Problems, Part 2: Effects of Inequality of Variance and of Correlation between Errors in the Two-Way Classification.”Annals of Mathematical Statistics 25:484–498.
Box, G. E. P., and Cox, D. R. (1964).“An Analysis of Transformations.”Journal of the Royal Statistical Society, Series B 26:211–243.
Box, G. E. P., and Meyer, R. D. (1986).“An Analysis for Unreplicated Fractional Factorials.”Technometrics 28:11–18.
Box, G. E. P., and Meyer, R. D. (1993).“Finding the Active Factors in Fractionated Screening Experiments.”Journal of Quality Technology 25:94–105.
Burnham, K. P., and Anderson, D. R. (2004).“Multimodel Inference: Understanding AIC and BIC in Model Selection.”Sociological Methods and Research 33:261–304.
Burnham, K. P., Andersen, D. R., and Huyvaert, K. P. (2011).“AIC Model Selection and Multimodel Inference in Behavioral Ecology: Some Background, Observations, and Comparisons.”Behavioral Ecology and Sociobiology 65:23–35.
Candes, E., and Tao, T. (2007).“The Dantzig Selector: Statistical Estimation when p is Much Larger than n.”The Annals of Statistics 35:2313–2351.
Carroll, R. J., and Ruppert, D. (1988).Transformation and Weighting in Regression.London: Chapman & Hall.
Chilès, J.-P., and Delfiner, P. (2012).Geostatistics: Modeling Spatial Uncertainty.2nd ed. New York: John Wiley & Sons.
Cobb, G. W. (1998).Introduction to Design and Analysis of Experiments.New York: Springer-Verlag.
Cohen, J. (1977).Statistical Power Analysis for the Behavioral Sciences.New York: Academic Press.
Cole, J. W. L., and Grizzle, J. E. (1966).“Applications of Multivariate Analysis of Variance to Repeated Measures Experiments.”Biometrics 22:810–828.
Conover, W. J. (1999).Practical Nonparametric Statistics.3rd ed. New York: John Wiley & Sons.
Cook, R. D., and Weisberg, S. (1982).Residuals and Influence in Regression.New York: Chapman & Hall.
Cook, R. D., and Weisberg, S. (1983).“Diagnostics for Heteroscedasticity in Regression.”Biometrika 70:1–10.
Cornell, J. A. (1990).Experiments with Mixtures.2nd ed. New York: John Wiley & Sons.
Cox, D. R. (1972).“Regression Models and Life-Tables.” Journal of the Royal Statistical Society, Series B 34:187–220.
Cox, D. R., and Snell, E. J. (1989).The Analysis of Binary Data.2nd ed. London: Chapman & Hall.
Cressie, N. A. C. (1993).Statistics for Spatial Data.Rev. ed. New York: John Wiley & Sons.
Daniel, C. (1959).“Use of Half-Normal Plots in Interpreting Factorial Two-Level Experiments.”Technometrics 1:311–341.
Dunnett, C. W. (1955).“A Multiple Comparisons Procedure for Comparing Several Treatments with a Control.”Journal of the American Statistical Association 50:1096–1121.
Dwass, M. (1955).“A Note on Simultaneous Confidence Intervals.”Annals of Mathematical Statistics 26:146–147.
Efron, B. (1977).“The Efficiency of Cox’s Likelihood Function for Censored Data.”Journal of the American Statistical Association 72:557–565.
Farebrother, R. W. (1987).“Mechanical Representations of the L1 and L2 Estimation Problems.”In Statistical Data Analysis Based on L1 Norm and Related Methods, edited by Y. Dodge, 455–464.Amsterdam: North-Holland.
Fieller, E. C. (1954).“Some Problems in Interval Estimation.”Journal of the Royal Statistical Society, Series B 16:175–185.
Firth, D. (1993).“Bias Reduction of Maximum Likelihood Estimates.”Biometrika 80:27–38.
Fleming, T. R., and Harrington, D. P. (1991).Counting Processes and Survival Analysis.New York: John & Sons.
Goodnight, J. H. (1978).Tests of Hypotheses in Fixed Effects Linear Models.Technical Report R–101, SAS Institute Inc., Cary, NC.
Goodnight, J. H., and Harvey, W. R. (1978).Least-Squares Means in the Fixed-Effects General Linear Models.Technical Report R-103, SAS Institute Inc., Cary, NC.
Goos, P., and Jones, B. (2011).Optimal Design of Experiments: A Case Study Approach.Chichester, UK: John Wiley & Sons.
Greenhouse, S. W., and Geisser, S. (1959).“On Methods in the Analysis of Profile Data.”Psychometrika 32:95–112.
Harrell, F. E. (1986).“The LOGIST Procedure.”In SUGI Supplemental Library Guide, Version 5 Edition.Cary, NC: SAS Institute Inc.
Harvey, A. C. (1976).“Estimating Regression Models with Multiplicative Heteroscedasticity.”Econometrica 44:461–465.
Hastie, T. J., Tibshirani, R. J., and Friedman, J. H. (2009).The Elements of Statistical Learning: Data Mining, Inference, and Prediction.2nd ed. New York: Springer-Verlag.
Hayter, A. J. (1984).“A Proof of the Conjecture That the Tukey-Kramer Method Is Conservative.”Annals of Statistics 12:61–75.
Heinze, G., and Schemper, M. (2002).“A Solution to the Problem of Separation in Logistic Regression.”Statistics in Medicine 21:2409–2419.
Hocking, R. R. (1985).The Analysis of Linear Models.Monterey, CA: Brooks/Cole.
Hoenig, J. M., and Heisey, D. M. (2001).“The Abuse of Power: The Pervasive Fallacy of Power Calculations for Data Analysis.”American Statistician 55:19–24.
Hoerl, A. (1962).“Application of Ridge Analysis to Regression Problems.”Chemical Engineering Progress 58:54–59.
Hoerl, A., and Kennard, R. (1970).“Ridge Regression: Biased Estimation for Non-orthogonal Problems.”Technometrics 12:55–67.
Hsu, J. C. (1992).“The Factor Analytic Approach to Simultaneous Inference in the General Linear Model.”Journal of Computational and Graphical Statistics 1:151–168.
Hsu, J. C. (1996).Multiple Comparisons: Theory and Methods.London: Chapman & Hall.
Hu, W., Laber, E. B., Barker, C., and Stefanski, L. A. (2019.“Assessing Tuning Parameter Selection Variability in Penalized Regression.”Technometrics 61:154–164.
Huber, P. J., and Ronchetti, E. M. (2009).Robust Statistics.2nd ed. John Wiley & Sons.
Hui, F., Warton, D., and Foster, S. (2015).“Tuning Parameter Selection for the Adaptive Lasso Using ERIC.”Journal of the American Statistical Association 110:262–269.
Huynh, H., and Feldt, L. S. (1970).“Conditions Under Which Mean Square Ratios in Repeated Measurements Designs Have Exact F-Distributions.”Journal of the American Statistical Association 65:1582–1589.
Huynh, H., and Feldt, L. S. (1976).“Estimation of the Box Correction for Degrees of Freedom from Sample Data in the Randomized Block and Split Plot Designs.”Journal of Educational Statistics 1:69–82.
Kackar, R. N., and Harville, D. A. (1984).“Approximations for Standard Errors of Estimators of Fixed and Random Effects in Mixed Linear Models.”Journal of the American Statistical Association 79:853–862.
Kalbfleisch, J. D., and Prentice, R. L. (2002).The Statistical Analysis of Failure Time Data.2nd ed. Hoboken, NJ: John Wiley & Sons.
Kenward, M. G., and Roger, J. H. (1997).“Small Sample Inference for Fixed Effects from Restricted Maximum Likelihood.”Biometrics 53:983–997.
Koenker, R., and Hallock, K. (2001).“Quantile Regression: An Introduction.”Journal of Economic Perspectives 15:143–156.
Kramer, C. Y. (1956).“Extension of Multiple Range Tests to Group Means with Unequal Numbers of Replications.”Biometrics 12:307–310.
Lemkus, T., Gotwalt, C., Ramsey, P., and Weese, M. (2021).“Self-Validated Ensemble Models for Design of Experiments.”Chemometrics and Intelligent Laboratory Systems 219:104439.
Lenth, R. V. (1989).“Quick and Easy Analysis of Unreplicated Factorials.”Technometrics 31:469–473.
Littell, R. C., Milliken, G. A., Stroup, W. W., Wolfinger, R. D., and Schabenberger, O. (2006).SAS for Mixed Models.2nd ed. Cary, NC: SAS Institute Inc.
Mallows, C. L. (1973).“Some Comments on Cp.”Technometrics 15:661–675.
Mardia, K. V., Kent, J. T., and Bibby, J. M. (1979).Multivariate Analysis.London: Academic Press.
McClave, J. T., and Dietrich, F. H. (1988).Statistics.San Francisco: Dellen.
McCullagh, P., and Nelder, J. A. (1989).Generalized Linear Models.2nd ed. London: Chapman & Hall.
McCulloch, C. E., Searle, S. R., and Neuhaus, J. M. (2008).Generalized, Linear, and Mixed Models.New York: John Wiley & Sons.
Meeker, W. Q., and Escobar, L. A. (1998).Statistical Methods for Reliability Data.New York: John Wiley & Sons.
Miller, A. J. (1990).Subset Selection in Regression.New York: Chapman & Hall.
Montgomery, D. C. (1991).“Using Fractional Factorial Designs for Robust Process Development.”Quality Engineering 3:193–205.
Muller, K. E., and Barton, C. N. (1989).“Approximate Power for Repeated-Measures ANOVA Lacking Sphericity.”Journal of the American Statistical Association 84:549–555.Also see “Correction to ‘Approximate Power for Repeated-Measures ANOVA Lacking Sphericity’,” Journal of the American Statistical Association 86 (1991): 255–256.
Nagelkerke, N. J. D. (1991).“A Note on a General Definition of the Coefficient of Determination.”Biometrika 78:691–692.
Nelder, J. A., and Wedderburn, R. W. M. (1972).“Generalized Linear Models.”Journal of the Royal Statistical Society, Series A 135:370–384.
Nelson, F. D. (1976).“On a General Computer Algorithm for the Analysis of Models with Limited Dependent Variables.”Annals of Economic and Social Measurement 5:493–509.
Nelson, P. R., Wludyka, P. S., and Copeland, K. A. F. (2005).The Analysis of Means: A Graphical Method for Comparing Means, Rates, and Proportions.Philadelphia: SIAM.
Patterson, H. D., and Thompson, R. (1974).“Maximum Likelihood Estimation of Components of Variance.”In Proceedings of the Eighth International Biometric Conference, 197–207.Washington, DC: International Biometric Society.
Portnoy, S., and Koenker, R. (1997).“The Gaussian Hare and the Laplacian Tortoise: Computation of Squared-Error vs. Absolute-Error Estimators.”Statistical Science 12:279–300.
Rawlings, J. O. (1988).Applied Regression Analysis: A Research Tool.Pacific Grove, CA: Wadsworth & Brooks/Cole Advanced Books & Software.
Ries, P. N., and Smith, H. (1963).“The Use of Chi-Square for Preference Testing in Multidimensional Problems.”Chemical Engineering Progress 59:39–43.
Sall, J. P. (1990).“Leverage Plots for General Linear Hypotheses.”American Statistician 44:308–315.
SAS Institute Inc.(2020a).“The GENMOD Procedure.”In SAS/STAT 15.2 User’s Guide.Cary, NC: SAS Institute Inc. https://go.documentation.sas.com/api/docsets/statug/15.2/content/genmod.pdf.
SAS Institute Inc.(2020b).“The GLM Procedure.”In SAS/STAT 15.2 User’s Guide.Cary, NC: SAS Institute Inc. https://go.documentation.sas.com/api/docsets/statug/15.2/content/glm.pdf.
SAS Institute Inc.(2020c).“Introduction to Statistical Modeling with SAS/STAT Software.”In SAS/STAT 15.2 User’s Guide.Cary, NC: SAS Institute Inc. https://go.documentation.sas.com/api/docsets/statug/15.2/content/intromod.pdf.
SAS Institute Inc.(2020d).“The MIXED Procedure.”In SAS/STAT 15.2 User’s Guide.Cary, NC: SAS Institute Inc. https://go.documentation.sas.com/api/docsets/statug/15.2/content/mixed.pdf.
Satterthwaite, F. E. (1946).“An Approximate Distribution of Estimates of Variance Components.”Biometrics Bulletin 2:110–114.
Scheffé, H. (1958).“Experiments with Mixtures.”Journal of the Royal Statistical Society, Series B 20:344–360.
Schuirmann, D. J. (1987).“A Comparison of the Two One-Sided Tests Procedure and the Power Approach for Assessing the Equivalence of Average Bioavailability.”Journal of Pharmacokinetics and Biopharmaceutics 15:657–680.
Searle, S. R., Casella, G., and McCulloch, C. E. (1992).Variance Components.New York: John Wiley & Sons.
Seber, G. A. F. (1984).Multivariate Observations.New York: John Wiley & Sons.
Singer, J. D. (1998).“Using SAS PROC MIXED to Fit Multilevel Models, Hierarchical Models, and Individual Growth Models.”Journal of Educational and Behavioral Statistics 23:323–355.
Snedecor, G. W., and Cochran, W. G. (1967).Statistical Methods.6th ed. Ames: Iowa State University Press.
Spiller, S. A., Fitzsimons, G. J., Lynch, J. G., Jr., and McClelland, G. (2013).“Spotlights, Floodlights, and the Magic Number Zero: Simple Effects Tests in Moderated Regression.”Journal of Marketing Research 50:277–288.
Stone, C., and Koo, C. Y. (1985).“Additive Splines in Statistics.”In Proceedings of the Statistical Computing Section, 45–48.Alexandria, VA: American Statistical Association.
Sullivan, L. M., Dukes, K. A., and Losina, E. (1999).“An Introduction to Hierarchical Linear Modelling.”Statistics in Medicine 18:855–888.
Tibshirani, R. (1996).“Regression Shrinkage and Selection via the Lasso.”Journal of the Royal Statistical Society, Series B 58:267–288.
Tukey, J. W. (1953).“The Problem of Multiple Comparisons.”In Multiple Comparisons, 1948–1983, edited by H. I. Braun, vol. 8 of The Collected Works of John W. Tukey (published 1994), 1–300.London: Chapman & Hall.Unpublished manuscript.
Walker, S. H., and Duncan, D. B. (1967).“Estimation of the Probability of an Event as a Function of Several Independent Variables.”Biometrika 54:167–179.
Westfall, P. H., Tobias, R. D., and Wolfinger, R. D. (2011).Multiple Comparisons and Multiple Tests Using SAS.2nd ed. Cary, NC: SAS Institute Inc.
Wilks, S. S. (1938).“The Large-Sample Distribution of the Likelihood Ratio for Testing Composite Hypotheses.”Annals of Mathematical Statistics.9:60–62.
Wolfinger, R. D., Tobias, R. D., and Sall, J. (1994).“Computing Gaussian Likelihoods and Their Derivatives for General Linear Mixed Models.”SIAM Journal on Scientific Computing 15:1294–1310.
Wright, S. P., and O’Brien, R. G. (1988).“Power Analysis in an Enhanced GLM Procedure: What it Might Look Like.”In Proceedings of the Thirteenth Annual SAS Users Group International Conference, 1097–1102.Cary, NC: SAS Institute Inc. https://support.sas.com/resources/papers/proceedings-archive/SUGI88/Sugi-13-220%20Wright%20OBrien.pdf.
Zou, H. (2006).“The Adaptive Lasso and Its Oracle Properties.”Journal of the American Statistical Association 101:1418–1429.
Zou, H., and Hastie, T. (2005).“Regularization and Variable Selection via the Elastic Net.”Journal of the Royal Statistical Society, Series B 67:301–320.
