发布日期: 09/18/2023
SAS Server Object Messages
sasconn<<Assign Libref(libref, path, engine, engine options)
Description
Assign a SAS libref on this SAS server connection.
Returns
Void.
Arguments
See SAS Assign Lib Refs("libref", "path", <"engine">, <"engine options">).
sasconn<<Cancel Submit()
Description
Cancels the currently running SAS Submit for this server that is presumably running asynchronously.
Returns
1 if a running submit was found and canceled; 0 otherwise.
sasconn<<Clear Log History()
Description
Clears the SAS Log history for this server.
Returns
Void.
sasconn<<Clear Output History()
Clears the SAS Output history for this server.
sasconn<<Connect(<User Name(name)>, <Password(password)>, <Prompt("Always"|"Never"|"IfNeeded")>)
Description
Attempt to reconnect a SAS server connection object that has become disconnected.
Returns
1 if the connection was successful, 0 otherwise.
Optional Named Arguments
User Name(name)
Specifies the quoted user name for the connection.
Password(password)
Specifies the quoted password for the connection.
Prompt
A quoted keyword. "Always" means always prompt before attempt to connect. "Never" means never prompt even if the connection attempt fails (just fail with an error message going to the log), and "IfNeeded" (the default) means prompt if the attempt to connect with the given arguments fails (or is not possible with the information given).
sasconn<<Deassign Libref(libref)
Description
De-assign the quoted SAS libref on this SAS server connection.
Returns
Void.
Arguments
libref
Specifies the quoted library reference.
sasconn<<Disconnect()
Description
Disconnect this SAS server connection.
Returns
Void.
sasconn<Does Module Exist(module name)
Description
Determines whether the specified SAS module exists in the SAS installation represented by the SAS connection. This can be helpful in determining whether certain SAS products are installed. The SAS DATA Step function MODEXIST is used to determine module existence.
Returns
1 if the specified module is found to exist, 0 if it does not exist.
Argument
module name
Specifies the quoted SAS module, the existence of which should be checked. Do not include any extension.
sasconn<<Export Data(dt, library, dataset, <named arguments>)
Description
Exports a JMP data table to the specified SAS data set in the specified library on the active SAS server connection.
Returns
1 if the data table was exported successfully; 0 otherwise.
See SAS Export Data(dt, "library", "dataset", <named_arguments>).
sasconn<<Get Data Sets(libref)
Description
Returns a list of the data sets defined in a SAS library on this SAS server connection.
Returns
A list of quoted strings.
Arguments
libref
Specifies the quoted SAS libref or friendly library name associated with the library for which the list of defined SAS data sets will be returned.
sasconn<<Get Error Count()
Description
Gets the count of the number of errors encountered in the previous SAS Submit.
Returns
An integer.
sasconn<<Get File(source, dest)
Description
Downloads a file from this SAS server connection.
Returns
Void.
Arguments
See SAS Get File("source", "dest", "encoding").
sasconn<<Get File Names(fileref)
Description
Gets a list of filenames found in the quoted fileref on this SAS server connection.
Returns
Arguments
fileref
A quoted string that contains the name of fileref from which to retrieve filenames.
sasconn<<Get File Names In Path(path)
Description
Gets a list of filenames found in the quoted path on the current SAS server connection.
Returns
Arguments
path
The quoted directory path on the server from which to retrieve filenames.
sasconn<<Get File Refs()
Description
Gets a list of the currently defined SAS filerefs on this SAS server connection.
Returns
sasconn<<Get Librefs(<named arguments>)
Description
Gets a list of the currently defined SAS librefs on this SAS server connection.
Returns
See SAS Get Lib Refs(<named arguments>).
sasconn<<Get Log()
Description
Retrieves the SAS Log from the last SAS Submit from this SAS server connection.
Returns
A quoted string.
sasconn<<Get Option Name()
Description
Queries SAS for the value of a SAS option variable.
Returns
A quoted string.
Example
The following script iterates through the define variables and prints out the values:
option_names = sasconn << Get Option Names();
For(i=1, i <= N Items(option_names), i++,
	option_value = sasconn << Get Option Value (option_names[i]);
	output = option_names[i] || "=" || char(option_value) || "/!n";
	Write(output);
sasconn<<Get Output()
Description
Retrieves the listing output from the last submission of SAS code to this SASServer object.
Returns
A quoted string.
sasconn<<Get Results()
Description
Retrieves the results of the previous SAS Submit as a scriptable object, which allows significant flexibility in what to do with the results.
Returns
A SAS Results Scriptable Object.
sasconn<<Get Submit Status()
Description
Gets the current status of a SAS Submit for this server that is presumably running asynchronously.
Returns
1 if the submit has not started; 2 if the submit is running; 3 if the submit has been canceled; 10 if the submit has completed successfully; 11 if the submit has completed with errors.
sasconn<<Get Var Info(libref, dataset, <Password(password)>)
Description
Returns information about the variables the specified SAS data set.
Required Arguments
libref
The library name.
dataset
The quoted name of the data set from which to retrieve variable names.
Optional Argument
Password(password)
The quoted password for the connection.
sasconn<<Get Var Names(libref, dataset, <named arguments>)
Description
Retrieves the variable names contained in the specified data set on this SAS server connection.
Returns
Arguments
See SAS Get Var Names(string, <"dataset">, <password("password")>).
sasconn<<Get Version(<"Long">)
Description
Returns the SAS version as a quoted string such as “9.4”.
Returns
A quoted string that contains the SAS version.
Optional Argument
Long
A quoted keyword that specifies to return the long SAS version, which corresponds to the SYSVLONG SAS macro (for example, "9.02.02M0P01152009").
sasconn<<Get Work Folder()
Description
Returns the full path of the folder corresponding to the WORK library for this server.
Returns
A quoted string that specifies the work folder path.
sasconn<<Import Data(library, dataset, <named arguments>)
Description
Imports a SAS data set from this SAS server connection into a JMP table.
Returns
A JMP Data Table object.
Arguments
See SAS Import Data(string, <"dataset">, <named arguments>).
sasconn<<Import Query(sqlquery, <named arguments>)
Description
Executes the requested SQL query on this SAS server connection, importing the results into a JMP data table.
Returns
A JMP data table object.
Arguments
See SAS Import Query("sqlquery", <named arguments>).
sasconn<<Is Connected()
Description
Determines whether this SAS Server object is currently connected to SAS.
Returns
1 if sasconn is connect, 0 otherwise.
sasconn<<Is Product Available(product name)
Description
Determines whether the quoted SAS product is both licensed and installed in the session represented by the SAS connection. The SAS DATA Step functions SYSPROD and MODEXIST are used to determine the licensed and installed status of the product.
Returns
1 if the specified product is licensed, 0 if the product is not licensed, or -1 if the specified product is not recognized by SAS. This function throws an exception if the requested product is not one for which JMP knows how to check the installed status.
Required Argument
product name
The quoted SAS product for which licensing should be checked. The product name can be specified with or without the “SAS/” prefix.
sasconn<<Is Product Licensed(product name)
Description
Determines whether the quoted SAS product is licensed in the session represented by the SAS connection. The SAS DATA Step function SYSPROD is used to determine the licensing status of the product.
Returns
Required Argument
product name
sasconn<<Kill Session(<n>)
Description
If no argument is provided, the SAS connection is immediately terminated.
Returns
Void.
Arguments
n
An optional number. The system waits n seconds for a normal shut-down before immediately terminating the SAS connection.
sasconn<<Load Text File(path, <named arguments>)
Description
Downloads the file specified in the quoted path from the active SAS server connection and retrieve its contents as a quoted string.
Returns
A quoted string.
Arguments
See SAS Load Text File("path").
sasconn<<Open Log Window()
Description
Opens (or brings to the front) the SAS Log window for this server.
Returns
Void.
sasconn<<Open Output Window()
Description
Opens (or brings to the front) the SAS Output window for this server.
Returns
Void.
sasconn<<Open SAS Results()
Description
Opens the results from the previous SAS Submit. Intended to be used with asynchronous SAS submits or the use of the OnSubmitComplete option to SAS Submit to give the JSL author a way to conditionally open the results of a submit.
Returns
Void.
sasconn<<Open Submit Results()
Description
Opens all the results from the last SAS Submit command.
Returns
Void.
sasconn<<Send File(source, dest)
Description
Uploads a file to this SAS server connection.
Returns
Void.
Arguments
See SAS Send File("source", "dest", "encoding").
sasconn<<Submit(sas code, <named arguments>)
Description
Submits quoted SAS code to this SAS server connection.
Returns
Void.
Arguments
See SAS Submit("sasCode", <named arguments>).
sasconn<<Submit File(filename, <named arguments>)
Description
Submits a SAS code file to this SAS server connection.
Returns
Void.
Arguments
See SAS Submit File("filename", <named arguments>).
