Scripting Guide > Display Trees > Technical Details for Display Trees
发布日期: 09/18/2023
Tab Page Box() organizes the title and contents of the page in one display box. When Tab Page Box() is inside Tab Box(), a tabbed window with multiple tabbed pages appears. See Tab Box and Tab Page Box.
In previous versions of JMP, display boxes such as V List Box() contained tab contents. Consider the following script:
win = New Window( "Tab Box",
	tb = Tab Box(
		"First page", // name of the tab
		V List Box( // tab contents
			Text Box( "first line of first page" ),
			Text Box( "second line of first page" )
		"Second page", // name of the tab
			Text Box( "first line of second page" ),
			Text Box( "second line of second page" )
We recommend that Tab Box() contain a Tab Page Box() for each tab. The preceding example is rewritten as follows:
	tb = Tab Box(
		Tab Page Box( // tab contents
			Title( "First page of my tab box" ), // name of the tab
			Title( "Second page" ), // name of the tab
Note: Tab Page Box() requires that the title be defined in a Title() function.
When a tab page box is created or dragged outside a tab box, the tab page box is a stand-alone container. The title appears in a shaded box at the top of the page, similar to the title in Sheet Part(); the title does not appear in an interactive tab. Dashboard with One Row of Reports provides an example.
Deprecated Tab Box and Tab Page Box Messages
Some messages previously used for Tab Box() are deprecated. Their counterparts are compatible with Tab Page Box().
Table 11.5 Deprecated Tab Box() Messages
Deprecated Tab Box Message
Current Tab Page Box Message
Set Title
Title
Set Tip
Tip
Set Icon
Icon
Set Closeable
Closeable
See Tab Box and Tab Page Box for more information about the two display boxes.
