Scripting Guide > Display Trees
发布日期: 09/18/2023
Display Trees
Create and Interact with Windows
After you learn the basics of scripting, you’re ready to manipulate JMP reports and create new JMP windows. This chapter focuses on the following topics:
navigating JMP display trees to manipulate items in report windows
building new windows with custom results
building modal windows
interacting with the script editor
converting deprecated Dialog() scripts to New Window() scripts
Display Tree Compatibility Issues
JMP platforms are generally stable from release to release. However, sometimes the structure of reports changes in major releases. When this happens, old scripts can fail because of the new structure. To avoid the continual updating of old scripts, write scripts so that they avoid dependence on the report structure. Using a string to index a box, followed by a numbered subscript to pick a specific child box, is most reliable across releases. See Create a Reference by Subscripting. See Compatibility Notes for compatibility issues in JMP 17.
Note: This chapter shows how to create and use the most common display boxes. All display boxes are documented in the JMP Scripting Index, which is available in the Help menu.
Contents
Structure of JMP Reports
Examples of Display Boxes
Show the Display Tree
Edit Display Box Properties
Get References to Display Box Objects
Send Messages to Display Boxes
Example of Creating a Report
Construct Custom Windows
Example of Creating a Graph Box
Extract Values from a Window
Construct Display Boxes for New Windows
Close a Window
Add and Delete Display Boxes
Set Function and Set Script
Get and Set Selected Values of Display Elements That Return Lists
Send Messages to Constructed Displays
Construct Display Boxes That Contain Platforms
Counting the Number of Child Boxes
Examples of Creating a Dashboard from Two Reports
Example of Creating a Cluster Platform Launch Window
Example of Constructing a Custom Platform
Example of Specifying Text and Background Colors
Modal Windows in JSL
Construct a Modal Window
Construct a Column Dialog
Comparison of Column Dialog and New Window
Constructors for Column Dialogs
Convert Deprecated Dialog to New Window
New Window Example
Example of Deprecated Dialog
Differences Between New Window and the Deprecated Dialog
Optional Scripts in New Window
Scripting the Script Editor
Technical Details for Display Trees
