JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Creating Applications
• Compile Add-Ins with the JMP Add-In Builder
上一个
下一个
A JMP add-in is a JSL script that you can run anytime from the JMP Add-Ins menu. You can create submenus to group your JMP add-ins and have many levels of menus, if desired.
Experienced JSL script writers can create scripts that extend JMP in many ways (for example, add a custom analytical tool or a user interface to communicate with a database). The JMP add-in architecture simplifies deploying and using these complicated scripts.
You can send co-workers a suite of scripts and tell them how to run them. Another option is sending a single add-in file that any JMP user can install and then use just like any other part of JMP.
As a JMP user, you might be given add-ins to use by co-workers. You can also find add-ins on the JMP website at
https://www.jmp.com/addins
