JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Creating Applications
Compile Add-Ins with the JMP Add-In Builder
• Share an Add-In
上一个
下一个
Share an Add-In
Once you have a .
jmpaddin
file, you can share the file with other users. Email the file or you place it in a shared location, such as a network folder, or on the JMP File Exchange (located online in the
JMP User Community
When JMP users open the file, the add-in files are extracted into the appropriate folder, and the add-in is registered and installed. The add-in now appears in the user’s JMP Add-Ins menu.
