JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Creating Applications
Create Applications with Application Builder
• Design an Application
上一个
下一个
Before creating the application, you must identify its purpose, decide on which graphical elements to include, and figure out which JSL scripts you need to write.
Purpose
What do you want the application to accomplish? Which features of JMP do you need to customize (for example, a launch window, report, or graph)?
Graphical Elements
How many modules do you need? Look at the list of graphical objects in Application Builder and decide which objects to include in your application. The Sources pane shows dozens of boxes and icons that you can drag and drop into a module. Also look at the preinstalled samples to see whether a similar module exists.
Scripting
Depending on the complexity of the application, you write JSL scripts. See
Write Scripts
for details about writing scripts for an application.
A non-interactive application that only shows objects does not require scripts. One example is a window showing reports that you have already generated in JMP.
