图 16.4 shows an application under development in Application Builder.
图 16.4 The Application Builder Window
提示:To hide the grid and turn off snap-to-grid for all applications that you create, select File > Preferences > Platforms > JMP App and deselect these options. You can also deselect these features in the Application Builder red triangle menu.
