Opens a sample application from the JMP Samples/Apps folder. These samples show you how to set up common applications, and you can modify them as you wish. Sample Applications Installed with JMP describes the samples.
A modified version of Instant App.jmpappsource. Options for selecting the principal components report, changing the marker size, and showing means are included.
