The following example creates a summary table from the Fitness.jmp sample data table. The N Rows column, which specifies the number of rows for each level, is included in the Summary table by default. This script creates a column of the mean for Runtime by Sex.
dt << Summary(
dt << Summary(
Weight( "none" )
To unlink the Summary table, include Link to Original Data Table( 0 ) in the script.
dt << Summary(
