JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Data Tables
• Advanced Data Table Scripting
上一个
下一个
This section covers more advanced actions that you can perform on a data table.
Select Columns in a Data Table
Import Multiple Files
Store Summary Statistics in Global Variables
Create a Table of Summary Statistics
Subset a Data Table
Add a Data Filter
Sort a Data Table
Stack Values in a Data Table
Split Values in a Stacked Data Table
Transpose a Data Table
Vertically Concatenate Data Tables
Horizontally Concatenate Data Tables
Virtually Join Data Tables
Replace Data in Data Tables
Create a Table Using Tabulate
Copy Data Tables
Find Missing Data Patterns
Compare Data Tables
Create a Summary Table
Subscribe to a Data Table
Move Data Between Matrices and Data Tables
Add Hyperlinks to Text Columns
