JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Data Tables
Columns
• Add a Column Switcher
上一个
下一个
Use JSL to add a Column Switcher panel to a report window. The Column Switcher lets you quickly analyze different variables without having to re-create your analysis.
obj << Column Switcher(<default_col>(<col1>, <col2>, ...);
// add a Column Switcher to the report
obj << Remove Column Switcher();
// remove the Column Switcher from a report
For example, add the Column Switcher to a Contingency report for the
Car Poll.jmp
data as follows:
dt =
Open
"$SAMPLE_DATA/Car Poll.jmp"
obj =
Contingency
Y( :size ),
X( :marital status )
ColumnSwitcherObject = obj <<
Column Switcher
:marital status,
{:sex, :country, :marital status}
ColumnSwitcherObject <<
Set Size
200
// number of pixels for the switcher width
Set NLines
6
// number of columns to display in the switcher
For more details about the Column Switcher, see
“列转换程序”
in the
Using JMP
book.
