In order to speed up changes, use Begin Data Update before the changes to block these update messages. Use End Data Update after the changes have been completed to release the messages and update the displays.
Be sure to always send the End Data Update message, otherwise the display is not updated until forced to do so in some other way.
注意:Begin Data Update does not affect the data refresh due to some other table manipulations. For example, when you delete or add columns, the data table is updated and then the data update begins.
