Data tables store observation data, or measurements of various variables on a specific set of subjects. However, JMP data tables can also store metadata, or data about the data.
Table variables are for storing a single text string value, such as “Notes”. To understand how variables work, first get its existing value by sending a Get Table Variable message:
Now change the existing value of the string using Set Table Variable or New Table Variable, and then use Get Table Variable again to check that the string has been updated:
myvar = "This is my version of the JMP Big Class sample data.";
