JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Scripting Tools
Using the Script Editor
• Find and Replace
上一个
下一个
Find and Replace
Many find and replace options are available in the script editor, including the support of regular expressions. For example, searching with the following regular expression:
get.*name
returns messages such as “Get Button Name”, and “GetFontName”
Basic regular expressions such as
and
(which match the start of line and end of line) and
\n
(which matches a carriage return) are also supported.
See
““查找”窗口选项”
in the
Using JMP
book for details about the Search options.
