JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Scripting Tools
Using the Script Editor
• Drag and Drop Text
上一个
下一个
Drag and Drop Text
You can drag and drop text within a script editor window or between windows or from a data table into a script editor window. On Windows, pressing CTRL before dragging and dropping copies the text. On Macintosh, the text is copied by default.
Drag and drop text as follows:
Select a row or column, pause, and then drop it into the script editor window.
Double-click text in a text field and then drop it into the script editor window. Examples are text in a data table cell and any other selectable text.
On Windows, you can also drag and drop text into a minimized window.
Drag the text over the Home Window button
in the lower right corner of the window.
The Home Window appears.
In the Home Window list, drag the text over the destination window.
That window appears.
Drop the text where you want it.
