JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Scripting Tools
Using the Script Editor
• Color Coding
上一个
下一个
Color Coding
On Windows, the default font in the script editor is 10-point Consolas. On Macintosh, the default script editor font is 13-point Menlo.
JMP applies the following colors in the script window:
black for text, identifiers (JSL functions), braces, and user macros
white for the script editor background
gray for the disabled background and guides
green for comments
purple for strings
maroon for platform names
注意:
If a platform name is used in a message, the JSL messages color is used.
teal blue for numbers
dark blue for operator symbols, the first keyword, and JSL messages
medium blue for function names, second and third keywords, and macros
red for unknown objects
You can customize colors and fonts in the Customize Styles section of the Script Editor preferences. Syntax coloring for JSL, the log, SAS code, JavaScript, Text, JMP Text Analytics, R, Matlab, Python, C, JSON, and SQL are supported.
