JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Scripting Tools
Using the Script Editor
• Auto Complete Functions
上一个
下一个
If you do not remember the exact name of a function, use auto completion to see a list of functions that match what you have typed so far. Type part of the name, and then press CTRL-SPACE on Windows (OPTION-ESC on Macintosh).
Suppose that you want to clear your JSL variables, but do not remember the command. You can type
clear
and then press CTRL-SPACE, to see a list of possible clear commands. Select the command that you want to insert.
图 4.3
Autocomplete Example
