The tooltip shows the syntax, arguments, and a brief explanation of the function (图 4.4). The tip also appears in the script editor window status bar.
图 4.4 Tooltip for a JSL Function
To turn off function tooltips, deselect Preferences > Script Editor > Show Operator Tips.
