Select File > Open.
In the Open as section, select Data, using best guess.
提示:The import script is an Open() expression that specifies the text file and the import options to correctly import the file into JMP. The first part of this expression is the pathname to the specific file that you imported. If you save this script and want to run it a different place, you might need to edit the pathname so that it points to the text file. Pathnames are discussed in greater detail in “Path Variables” on page 129 in the “Types of Data” chapter.
