Open a new script window (File > New > Script).
In your script window, enter the Open() expression to open the Solubil.xls sample import data file. The file is located in JMP’s Samples/Import Data folder.
dt = Open( "$SAMPLE_IMPORT_DATA/Solubil.xls" );
注意:
You can also include the Excel Wizard argument in the Open() expression to preview the worksheet before importing it. See “Import Data from a Microsoft Excel File” on page 318 in the “Data Tables” chapter for details.
Select all the columns except Labels and click Y, Columns.
Hold down CTRL and select Histogram Options > Show Counts from the red triangle menu for eth.
In the Distribution window, select Save Script > To Clipboard from the red triangle menu next to Distributions.
6.
8.
Select Graph > Scatterplot 3D.
9.
10.
12.
Select Analyze > Multivariate Methods > Multivariate.
13.
14.
Continuous Distribution( Column( :eth ), Show Counts( 1 ) ),
Continuous Distribution( Column( :oct ), Show Counts( 1 ) ),
Continuous Distribution( Column( :cc14 ), Show Counts( 1 ) ),
Continuous Distribution( Column( :c6c6 ), Show Counts( 1 ) ),
Continuous Distribution( Column( :hex ), Show Counts( 1 ) ),
Continuous Distribution( Column( :chc13 ), Show Counts( 1 ) ),
Frame3D( Set Grab Handles( 0 ), Set Rotation( -54, 0, 38) )
Scatterplot Matrix(
Click Save.
Select Edit > Run Script.
Select File > Open.
