JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Scripting Graphs
Add Lines, Arrows, Points, Shapes, and Text
• Specify Transparency
上一个
下一个
In a graphics environment (like a Frame Box), use the Transparency function to set the level of transparency. The argument, alpha, can be any number between zero and one. The value 0 means clear and drawing has no effect. The value 1 means completely opaque and is the usual drawing mode. Intermediate values build semi-transparent color layers on top of what has already been drawn below it. The following example script illustrates transparency with rectangles.
win =
New Window
"Transparency"
Graph Box
Frame Size
200
200
Pen Color
"gray"
Fill Color
"gray"
Transparency
0.25
Rect
0
40
60
0
1
Pen Color
"red"
Fill Color
"red"
Transparency
0.5
Rect
10
60
70
10
1
Pen Color
"green"
Fill Color
"green"
Transparency
0.75
Rect
50
90
90
50
1
Pen Color
"blue"
Fill Color
"blue"
Transparency
1
Rect
0
80
70
70
1
图 12.20
Transparency and Rectangles
