JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Scripting Graphs
Add Lines, Arrows, Points, Shapes, and Text
• Add Fill Patterns
上一个
下一个
Add Fill Patterns
Fill Pattern()
sets the pattern for filled areas.
Matrix Example
Specify a mask (a matrix of values between 0 and 1) or an image. Each value in the matrix creates a pixel.
win =
New Window
"Example"
Graph Box
Fill Pattern
1
0.5 0 0
0.5 0 0 1
0 0 1 0.5
0 1 0.5 0
Polygon
10 30 90
88 22 44
Named Pattern Example
Specify a name in quotation marks that corresponds to a pattern shown in
Fill Patterns
win =
New Window
"Named Pattern Example"
Graph Box
Fill Pattern
"vertical light"
Polygon
10 30 90
88 22 44
Graphic Example
Specify an image in quotation marks. If the image is not installed on the viewer’s computer, question marks appear in the shape.
win =
New Window
"Graphic Example"
Graph Box
Fill Pattern
Open
"$SAMPLE_IMAGES/pi.gif"
"gif"
Polygon
10 30 90
88 22 44
Fill Patterns
Pattern Name
Pattern
left slant light
right slant light
vertical light
horizontal light
grid light
hatch light
h wave light
v wave light
hollow circle
left slant medium
right slant medium
vertical medium
horizontal medium
grid medium
hatch medium
h wave medium
v wave medium
filled circle
left slant heavy
right slant heavy
vertical heavy
horizontal heavy
grid heavy
hatch heavy
h wave heavy
v wave heavy
diamond
left slant heavy b
right slant heavy b
random
square
square offset
wide
tall
checkerboard
grid dots
triangle up
triangle down
triangle left
triangle right
weave light
weave heavy
honeycomb
