In addition to the red triangle menu at the top of a report, some report windows contain embedded red triangle menus. These appear when you select an option that has sub-options, such as profilers. To execute options in embedded red triangle menus, use the Get Scriptable Object message. The following example creates a Life Distribution report then turns off the Confidence Intervals option in the Hazard Profiler red triangle menu:
obj = dt << Life Distribution(
<< Fit Lognormal
haz_prof << Confidence Intervals( 0 );
