This chapter is about scripting platforms, not reports. Platform object references and report object references receive different types of JSL messages. Platforms can run tests, draw plots, and so on. Reports can copy pictures, select display boxes, or close outline nodes. To learn about scripting reports, see the section “Navigate JMP Reports” on page 481 in the “Display Trees” chapter.
提示:For additional scripting help, see the JMP Scripting Index (Help > Scripting Index) and the JSL Syntax Reference.
