JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Scripting Platforms
Scripting-Only Messages and Arguments by Platform
• Neural
上一个
下一个
Neural
注意:
The Neural platform replaces the Neural Net platform. Scripts that use Neural Net are deprecated and might not work in the future. It is recommended to use the Neural platform for new scripts and update any old scripts using Neural Net to Neural.
The following message for Neural objects is available only in JSL:
neural_object << Get NBoost
// return the number of models used for boosting
The following JSL messages for Neural Fit objects return the requested item from the fitted model, such as entropy RSquare, generalized RSquare, misclassification rates, and so on:
neural_object << ( Fit[n] << Get RSquare Training )
neural_object << ( Fit[n] << Get RSquare Validation )
neural_object << ( Fit[n] << Get RSquare Test )
neural_object << ( Fit[n] << Get Gen RSquare Training )
neural_object << ( Fit[n] << Get Gen RSquare Validation )
neural_object << ( Fit[n] << Get Gen RSquare Test )
neural_object << ( Fit[n] << Get Misclassification Rate Training )
neural_object << ( Fit[n] << Get Misclassification Rate Validation )
neural_object << ( Fit[n] << Get Misclassification Rate Test )
neural_object << ( Fit[n] << Get Average Log Error Training )
neural_object << ( Fit[n] << Get Average Log Error Validation )
neural_object << ( Fit[n] << Get Average Log Error Test )
neural_object << ( Fit[n] << Get RMS Error Training )
neural_object << ( Fit[n] << Get RMS Error Validation )
neural_object << ( Fit[n] << Get RMS Error Test )
neural_object << ( Fit[n] << Get Average Absolute Error Training )
neural_object << ( Fit[n] << Get Average Absolute Error Validation )
neural_object << ( Fit[n] << Get Average Absolute Error Test )
neural_object << ( Fit[n] << Get ROC Area Training )
neural_object << ( Fit[n] << Get ROC Area Validation)
neural_object << ( Fit[n] << Get ROC Area Test)
neural_object << ( Fit[n] << Get Confusion Matrix Training)
neural_object << ( Fit[n] << Get Confusion Matrix Validation)
neural_object << ( Fit[n] << Get Confusion Matrix Test)
neural_object << ( Fit[n] << Get Confusion Rates Training)
neural_object << ( Fit[n] << Get Confusion Rates Validation)
neural_object << ( Fit[n] << Get Confusion Rates Test)
neural_object << ( Fit[n] << Get Seconds)
