Once you have created a platform object, use the Show Properties( obj ) function. Replace obj with your named platform object. A list and brief description of all the messages the object can receive appears in the Log. To understand more about the Show Properties output, see Interpret the Show Properties List.
提示:The Show Properties() function also works with data tables and display boxes. See “How Can I See All of the Messages that Can be Sent to a Data Table Object?” on page 307 in the “Data Tables” chapter and “The << Operator” on page 492 in the “Display Trees” chapter.
