Suppose that you want to send a message to an object in the output. For example, in Fit Model, you want to send the Response Limits message to the Profiler object, Use the subscript operator ([ ]) to refer to the Profiler object.
fm = dt << Fit Model(
obj = fm << Profiler(
Importance( 1 )}
