The Include() function opens a script file, parses the script in it, and executes the JSL in the specified file.
See Advanced Scoping and Namespaces for information about using namespaces with your scripts.
Files with the .txt extension are treated as a JSL file. A text file that contains data can be included, however an error will appear since this is not valid JSL.
