JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Programming Methods
Advanced Programming Concepts
• Load and Save Text Files
上一个
下一个
The
Load Text File()
and
Save Text File()
commands allow manipulation of text files from JSL. Note that the paths in the following code are strings.
text = Load Text File( "path" );
Save Text File( "path", text );
You can load a text file from a Web site:
Load Text File( "URL", <blob> );
The URL is a quoted string that contains the URL for the text file. The text file is returned as a string. If you add the optional named argument
blob
, a blob is returned instead.
