JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Efficient Scripts
• Scripting Numbers, Strings, Arrays, and Lists
上一个
下一个
Use a faster algorithm. Replacing an O(n^2) algorithm with an O(n) algorithm is faster than anything else. See
https://en.wikipedia.org/wiki/Big_O_notation
for more information.
Avoid concatenating long strings. 100s of characters is OK; 1,000,000s of characters will be slow if you build the string in 1,000,000s of operations.
Use numeric arrays (matrices, not lists).
Use numeric arrays with operators that operate on the entire array.
Avoid writing loops to manipulate numeric arrays.
Use associative arrays for lookups.
