JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
• Efficient Scripts
上一个
下一个
Efficient Scripts
Tips for Writing Scripts That Run Faster
This appendix provides ideas for writing scripts that run faster and more efficiently. For example, it is possible to control how much time is allocated to finding an optimal design. You can collapse outlines in a report that are not necessary. Or you can write static matrices, which is faster than developing them dynamically.
目录
Using Matrices
Design of Experiments
Scripting Data Tables
Scripting Graphs and Display Boxes
Scripting Numbers, Strings, Arrays, and Lists
Programming Tips
Troubleshooting
