{"Blue to Purple", {"Continuous", "Diverging"}, {{0, 0, 255},
{57, 108, 244}, "white", {128, 0, 100}}} );
The two points can also be enclosed in square brackets: Arrow(<pixellength>, [x1, x2], [y1, y2]).
Converts the color argument (including any JMP color) to a list of HLS values.
A list of the hue, lightness, and saturation components of color. The values range between 0 and 1.
The output from ColorToHLS() can either be assigned to a single list variable or to a list of three scalar variables:
hls = Color To HLS( 8 );
{h, l, s} = Color To HLS( 8 );
Show( hls, h, l, s );
Converts the color argument (including any JMP color) to a list of RGB values.
A list of the red, green, and blue components of color. The values range between 0 and 1.
The output from ColorToRGB() can either be assigned to a single list variable or to a list of three scalar variables:
rgb = Color To RGB( 8 );
{r, g, b} = Color To RGB( 8 );
Show( rgb, r, g, b );
The n values that describe zGridMatrix.
The m values that describe zGridMatrix.
An nxm matrix of values on some surface.
Draws sets of contour lines of the expression, a function of the two symbols. The z argument can be a single value or an index or matrix of values.
A matrix of x-coordinates.
A matrix of y-coordinates.
A matrix of 2 x-coordinates.
A matrix of 2 y-coordinates.
xMatrix and yMatrix should each contain exactly two values. The resulting coordinate pairs should follow the rules for drawing a rect(); the first point (given by the first value in xMatrix and the first value in yMatrix) must describe the top, left point in the rectangle, and the second point (given by the second value in xMatrix and the second value in yMatrix) must describe the bottom, right point in the rectangle.
Draws the text (or all the items if a list is specified) at the coordinates given by the matrix arguments.
Get Color Theme Details( "JMP Default" );
Get Color Theme Names( "diverging" );
Zexpr is a function in terms of the two following variables (a and b), whose values range from zlow to zhigh (2 to 10). Zcolor defines the two colors that are blended together (4 is green, 6 is orange).
Draws a horizontal line at y across the graph. If you specify start and end points on the x-axis (x1 and x2), the line is drawn horizontally at y from x1 to x2. You can also draw multiple lines by using a matrix of values in the y argument.
Places draggable marker at coordinates given by a, b. The first script is executed at drag and the second at mouseup.
Returns 1 or 0, indicating whether the point (x, y) is inside the polygon that is defined by the xx and yy vector arguments.
The vector arguments (xx, yy) can also be combined into a 2-column matrix (xyPolygon), allowing you to use three arguments instead of four. Also, x and y can be conformable vectors, and then a vector of 0s and 1s are returned based on whether each (x, y) pair is inside the polygon.
When the second argument is a character string and not n, then the second argument determines the color theme.
0 or Solid
1 or Dotted
2 or Dashed
3 or DashDot
4 or DashDotDot
Draws normal probability contours for k populations and two variables.
Draws an oval inside the rectangle whose diagonal has the coordinates (x1, y1) and (x2, y2). Fill is Boolean. If fill is 0, the oval is empty. If fill is nonzero, the oval is filled with the current fill color. The default value for fill is 0.
See “Create a Color Picker” chapter in the Scripting Guide for details.
Sets the origin, in graph coordinates, for subsequent Pixel Line To or Pixel Move To commands.
area = Polygon Area( {0, 0}, {0, 10}, {10, 10}, {10, 0} );
area = Polygon Area( [10 20 30], [10 30 20] );
{cx, cy} = Polygon Centroid( {0, 0}, {0, 10}, {10, 10}, {10, 0} );
centroid = Polygon Centroid( [10 20 30], [10 30 20] );
Draws a rectangle whose diagonal has the coordinates (x1, y1) and (x2, y2). Fill is Boolean. If fill is 0, the rectangle is empty. If fill is nonzero, the rectangle is filled with the current fill color. The default value for fill is 0.
A number that represents metadata such as whether the theme is continuous or categorical. Run Get Color Theme Details("name") on the color theme and use the flag that is returned.
Remove Color Theme( {"Yellow Blue", 0, {{255, 255, 0}, {0, 0, 255}}, {0.0, 1.0}} );
Draws the quoted string text at the given point, either the x and y axes or the left, bottom, right, and top axes.
Properties can be any of several named arguments: Center Justified, Right Justified, Erased, Boxed, Counterclockwise, Position, and named arguments. The position, named arguments, and strings can be added in any order. The position and named arguments apply to all the strings.
Sets the color for Text strings.
Sets the transparency of the current drawing, with alpha between 0 and 1 where 0 is clear (no drawing) and 1 is completely opaque (the default).
Draws a vertical line at x across the graph. If you specify start and end points on the y-axis (y1 and y2), the line is drawn vertically at x from y1 to y2. You can also draw multiple lines by using a matrix of values in the x argument.
Draws a plot of the function as the symbol is varied over the y-axis of the graph.
Returns the x-value for the left edge of the graphics frame.
Sets the range for the horizontal scale. The default value for xmin is 0, and the default value for xmax is 100.
Combines an expression of x(t) and y(t) to draw an x-y curve for the specified range of parameter t.
注意:Either inc() or steps() is needed if the default granularity misses details.
Returns the y-value for the bottom edge of the graphics frame.
