This appendix provides the names of all icons used in JMP. Specify the quoted icon name in the Icon Box() function to create a display box that contains the icon. For example, the following example constructs a display box that contains the Nominal icon.
Icon names can also be used in Button Box(), Tree Node(), Tree Box(), Tab Page Box(), command menu items in an add-in, and window objects.
