When passing a single argument to an aggregate function, that argument can be preceded by the keyword DISTINCT, which filters out duplicate values.
For all aggregations other than COUNT( * ), NULL and missing values are ignored.
AVG( num_expr )
COUNT( expr )
COUNT( * )
Counts the number of times expr is not NULL in the group. COUNT( * ) returns the total number of rows in the group.
Concatenates all non-NULL values of expr and returns them as a string. Numeric values of expr are converted to character. If separator is present, it is placed between the values. The default separator is a comma. DISTINCT can be used only with GROUP_CONCAT() if separator is not specified.
MAX( expr )
MIN( expr )
STDDEV_POP( num_expr )
Computes the population standard deviation of num_expr for the group.
STDDEV_SAMP( num_expr )
Computes the sample standard deviation of all num_expr for the group.
SUM( num_expr )
TOTAL( num_expr )
VAR_POP( num_expr )
Computes the population variance of num_expr for the group.
VAR_SAMP( num_expr )
Computes the sample variance of num_expr for the group.
