JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
JSL Messages
Other Objects
• Journals
上一个
下一个
Journals
jnl<<Save HTML(<"path">, <"format">)
Saves the journal as HTML.
path
A quoted string that contains the filepath for the saved HTML file (for example,
"c:/myFile.html"
format
The quoted graphic file format. JPG, PNG, and TIFF formats are supported. The graphics are saved in a subdirectory named
gfx
jnl<<Save RTF(<"path">, <"format">)
Saves the journal as an RTF file.
Arguments
path
A quoted string that contains the filepath for the saved RTF file (for example,
"c:/myFile.rtf"
format
The quoted file format for the embedded graphics. JPG, PNG, and TIF formats are supported.
jnl<<Save PDF(<"path">, <Show Page Setup(0|1)>, <Portrait(0|1)>)
Saves the journal as a PDF file.
Arguments
path
A quoted string that contains the filepath for the saved PDF file (for example,
"c:/myFile.pdf"
Show Page Setup
If set to true, opens the Page Setup window to let the user change the margin, magnification level, and other page layout options.
Portrait
Determines whether the page orientation is portrait or landscape. Overrides the user’s selection in the Show Page Setup window.
