The Query() JSL function performs a SQL query on selected tables and exports the data to a data table. The following example first assigns the t1 alias to Big Class.jmp. name, age greater than 13, and height are then selected from the t1 table.
Query( Table( dt, "t1" ),
"SELECT t1.name, t1.age, t1.height FROM t1
You can use SQL functions in a query. For example, SELECT CURRENT_TIMESTAMP returns the current UTC/GMT time stamp as a SQLite time string:
目录
